Multi-tasking Performance
Website: MPC-HC
Website: 7-Zip
Multi-tasking is a phrase with which we're all familiar, because most of us are now used to running multiple applications at the same time. However, to run multiple applications well you need a powerful (ideally multi-core) CPU and plenty of RAM.
Our multi-tasking test performs a massive file backup (with encryption) using 7-Zip, while simultaneously playing back an HD movie file using mplayer, making it a demanding test for any PC.
Intel Core i7-3770K (3.5GHz/4.8GHz)
Intel Core i7-2600K (3.4GHz/5GHz)
Intel Core i5-3570K (3.4GHz/5GHz)
Intel Core i7-4770K (3.5GHz/4.7GHz)
Intel Core i5-2500K (3.3GHz/5GHz)
Intel Core i5-4670K (3.4GHz/4.6GHz)
Intel Core i7-3930K (3.2GHz/4.7GHz)
Intel Core i5-2400 (3.1GHz)
AMD FX-8150 (3.6GHz/4.818GHz)
AMD FX-8350 (4GHz/4.8GHz)
Intel Core i3-2100 (3.1GHz)
AMD A10-6800K (4.1GHz/4.7GHz)
AMD A10-7850K (3.7GHz/4.4GHz)
AMD Phenom II X6 1100T Black Edition (3.3GHz/4.2GHz)
AMD FX-8120 (3.1GHz/4.65GHz)
Tranquil PC Abel H2-5
Intel NUC DC53427RKE (Core i5-3427U)
Intel NUC D33217CK (Core i3-3217U)
Score, higher is better
Intel Core i7-3960X Extreme Edition (3.3GHz/4.7GHz)
Intel Core i7-990X Extreme Edition (3.46GHz/4.6GHz)
Intel Core i7-920 (2.66GHz/4.04GHz)
1000
1500
2000
2500
3000
Posted by MSHunter - Mon Feb 24 2014 11:02
Posted by Corky42 - Mon Feb 24 2014 12:02
Posted by jamesn - Mon Feb 24 2014 12:20
Posted by Combatus - Mon Feb 24 2014 13:10
